Circuitry om GPIO pin
lpcware
Content originally posted in LPCWare by IanB on Mon Apr 20 13:22:27 MST 2015
What is the INTERNAL protection circuitry on a GPIO pin? Could someone give me a circuit diagram.
lpcware
Content originally posted in LPCWare by embd02161991 on Wed Apr 29 09:42:34 MST 2015
Hi Ian,
The ESD box is a standard cell consisting of diodes (reverse biased) or ground gated nmos to clamp the transient.
NXP Technical Support
lpcware
Content originally posted in LPCWare by IanB on Thu Apr 23 13:38:48 MST 2015
Come on LPCadmin, what's the answer?
lpcware
Content originally posted in LPCWare by IanB on Mon Apr 20 23:16:53 MST 2015
Yes, folks. What's in the box?
Every other manufacturer tells us!
Normally a bit of series resistance is all that's needed and the diodes to VDD and VSS take care of the rest, but if there's no VDD diode, do I need a zener to stop damage from positive-going spikes?
lpcware
Content originally posted in LPCWare by R2D2 on Mon Apr 20 16:23:23 MST 2015
Quote: embd02161991
Please check the "Standard I/O pad configuration" section in the datasheet.
:D
...which is showing a mysterouis ESD box...
lpcware
Content originally posted in LPCWare by embd02161991 on Mon Apr 20 16:13:30 MST 2015
Hi Ian,
