lpcware
Using RI timer LPC1317
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by aamir ali on Wed Jul 31 05:17:37 MST 2013
UM10524 says that "Power to the register interface (RI timer clock): In the SYSAHBCLKCTRL register, set
bit 25 in Table 19."
But bit25 in SYSAHBCLKCTRL  is reserved. So how to enable clock to RI timer.
Is there example code available. I didn't find example of RIT in keil example codes
