Ed:02: Failed on connect: Ee(07). Bad ACK returned from status - wire error :((
lpcware
Content originally posted in LPCWare by emimad on Mon Mar 23 16:39:37 MST 2015
Dear Sirs,
I'm a newbie with Cortex family so I need some help with an issue.
I've been programming few days (blinking leds and so on) in my brilliant LPC1347 rev.A without problems but today I've tried program a new code and received the following message:
Ed:02: Failed on connect: Ee(07). Bad ACK returned from status - wire error.
Et: Emu(0): Connected. Was: None. DpID:     EDB6. Info: HID64HS12
Error 0: (null)
Last sticky: 0. AIndex: 0
No MemAp selected
No Speed test
SWD Frequency: 50 KHz. RTCK: False. Vector catch: False.
Packet delay: 0  Poll delay: 0.
Pc: (100) Target Connection Failed
Onboard led P0_7 is blinking because last code did it, so LPC1374 is running properly.
I've read in other posts to try enter in Debug mode so I've made this:
- Unplug USB
- Pin P0_1 to GND
- Plug USB cable
- Release P0_1
- Pin P0_0 to GND to make a reset
- Release P0_0
- Try to program (no results)
Then I try to modify vector catch to TRUE (http://support.code-red-tech.com/CodeRedWiki/DebugAccessChip) without solving it.
Power lines are ok (3.3, 1.8->1.4v and 1.2v).
When I click to program flash, onboard led near LPC3154 (LPC-Link side) lights on briefly (less than 0.5s) and then appears the fatal message.
Can anybody help me please? :)
Kind Regards!
lpcware
Content originally posted in LPCWare by emimad on Fri Mar 27 02:23:11 MST 2015
That's exactly what I've been thinking since yesterday!!
At least I've learned a lot with this issue  ;-)
lpcware
Content originally posted in LPCWare by R2D2 on Thu Mar 26 10:16:09 MST 2015
Quote: emimad
The resistor in TAG_TCLK_SWCLK line was... unsoldered!  |(
R24 :quest:
Can't believe it, this little bastard is keeping us busy 3 days  :D
lpcware
Content originally posted in LPCWare by emimad on Thu Mar 26 09:51:02 MST 2015
Now, I can program the target with LPCxpresso IDE!!!
Thank you very much, your help has been great!!  ;-)
Regards.
lpcware
Content originally posted in LPCWare by R2D2 on Thu Mar 26 02:51:03 MST 2015
Quote: emimad
The target is uncut and I power it by USB connector from LPC-Link side.
That sounds fine. Unchanged hardware (except PIO0_3 pulled low), nothing connected, powered from LPC-link  :)
Can you measure SWD pins SWDIO (J4-4) and SWCLK (J4-6)?
They should show at least an attempt to communicate with the target while starting a debug session...
lpcware
Content originally posted in LPCWare by emimad on Thu Mar 26 00:50:46 MST 2015
Yes, I have a LPCxpresso 1347 rev A board: http://www.nxp.com/demoboard/OM13045.html
Datasheet: http://www.embeddedartists.com/sites/default/files/docs/schematics/LPCXpressoLPC1347revA.pdf
lpcware
Content originally posted in LPCWare by R2D2 on Wed Mar 25 17:16:21 MST 2015
Quote: emimad
Yes, erase all flash+CR protect
Since an empty chip is starting the bootloader (with PIO0_3 low, UART bootloader) that's the best way to get your SWD working again  :)
If that's not working you've either a damaged chip or your SWD isn't working  :((
I'm not sure which hardware you are using in detail, is it an original LPCXpresso1347?
Did you separate the target board from the LPC-link?
Do you power the boards from LPC-link USB connector?
lpcware
Content originally posted in LPCWare by emimad on Wed Mar 25 16:52:18 MST 2015
lpcware
Content originally posted in LPCWare by R2D2 on Wed Mar 25 16:46:48 MST 2015
Quote: emimad
But... with LPCxpresso IDE I can't program microcontroller.
I'd tried puting P0_3 to high and to low during reset and in both cases the same result :(
Did you erase the chip before with FlashMagic?
lpcware
Content originally posted in LPCWare by emimad on Wed Mar 25 16:41:11 MST 2015
OMG! that's the question! Since I connect P0_3 to GND during reset, I can communicate with Flash Magic again! R2D2 you're the Master of Universe!  ;-)
lpcware
Content originally posted in LPCWare by R2D2 on Wed Mar 25 15:03:07 MST 2015
Quote: emimad
Exactly like in the video on youtube.
ZeRo's video is showing a LPC11C24. You are using a LPC1347  :O
Both have 2 bootloaders, so it's useful to select the right one  :~
In your case: PIO0_3 is switching between USB and UART bootloader  :)
If PIO0_3 is high during Reset you are in USB bootloader, not UART bootloader  :D
lpcware
Content originally posted in LPCWare by emimad on Wed Mar 25 14:55:43 MST 2015
Im connecting P0_1 to GND and then plug USB cable.
The LED lights up slightly, and then release P0_1.
After that, try to read Device Signature.
EDIT: Right now, without doing anything... It works!
Really, I can't belive...
Sorry for the inconveniences... and thank you very much sincerely.
lpcware
Content originally posted in LPCWare by R2D2 on Wed Mar 25 13:35:09 MST 2015
Quote: emimad
I've installed Flash Magic and... doesn't detects LPC!!  :((
How are you switching to ISP?
lpcware
Content originally posted in LPCWare by emimad on Wed Mar 25 13:16:48 MST 2015
I can't beleave it!!!
I'm trying to program via LPCxpresso IDE but... same bad results!
I've installed LPC IDE in another PC and the same!
This morning I'd programmed a .hex file with flash magic without problems (blinking onboard led)... and erase flash before do it.
I'm really desesperated with this board, I can't understand what is wrong.
lpcware
Content originally posted in LPCWare by emimad on Wed Mar 25 08:25:46 MST 2015
Quote:
In general I wouldn't recommend to use ISP pins because that can generate a nasty surprise later  Smile
And here is (I think) the origin of all my problems  8-)
Yes, I'm smiling now... but not the last two days!
lpcware
Content originally posted in LPCWare by R2D2 on Wed Mar 25 08:16:23 MST 2015
Quote: emimad
Can I use P0_1 (ISP pin mode), P0_9 (SWO), P0_10 (SWCLK) and P0_15 (SWDIO) as pin OUTPUTS in my code?
Yes, you can  :)
Of course you are losing the ability to debug your target if you use SWD pins as GPIO  :((
That's not a good idea if you are still writing / testing your code...
PIO0_1 is sampled during reset. So you can use this pin later for something else (at least if it isn't pulled low during reset).
In general I wouldn't recommend to use ISP pins because that can generate a nasty surprise later  :)
lpcware
Content originally posted in LPCWare by emimad on Wed Mar 25 08:02:35 MST 2015
yabadabadoo!!!!
It's works!!!!! I connected by the rs232 converter and Flash Magic recognized properly and shows Bootloader ver. 5.2.
I erased all flash+code Rd Prot and then programed the .hex file.
Program is running correctly!
I'll try to program the target by LPCxpresso IDE this afternoon :)
Thank you very much, your help has been fantastic!  :)
lpcware
Content originally posted in LPCWare by R2D2 on Wed Mar 25 05:20:33 MST 2015
BTW: How to start with FlashMagic is shown here:
https://youtu.be/IfRQDQRm2xk
lpcware
Content originally posted in LPCWare by R2D2 on Tue Mar 24 15:56:31 MST 2015
Quote: emimad
Thanks! I have some ones at office... I'll ensure tomorrow if there are TTL 5V or 3.3V.
How I must connect it to the LPC?
I've added a picture above  :)
Usually 5V TTL versions are working, too.
It's not necessary to flash something. Just use ISP->'Read Device Signature'.
If you can read it, FlashMagic is working  :)
After that erase it with ISP->'Erase Flash' with enabled 'Erase all Flash + Code Read Protection'.
If that's working, your chip is empty again and SWD should work again  8-)
lpcware
Content originally posted in LPCWare by emimad on Tue Mar 24 15:55:35 MST 2015
I'm just created a .hex file adding post procees build steps:
arm-none-eabi-size "${BuildArtifactFileName}"
arm-none-eabi-objcopy -v -O binary "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin"
checksum -v "${BuildArtifactFileBaseName}.bin"
arm-none-eabi-objcopy -I binary "${BuildArtifactFileBaseName}.bin" -O ihex "${BuildArtifactFileBaseName}.hex"
8-)
I hope to get better results tomorrow.
Thanks to all  :)
lpcware
Content originally posted in LPCWare by R2D2 on Tue Mar 24 15:39:30 MST 2015
To use a 3.3V UART you need a UART-USB converter :)
Something like:
http://www.ftdichip.com/Products/Cables/USBTTLSerial.htm
or a DIY version with an FTDI chip:
[img=360x173]http://www.lpcware.com/system/files/FTDI_0.JPG[/img]
That's an important tool, so everybody has one (or should have one)...
That's generating an USB COM port from your 3.3V UART and you can use FlashMagic  :)
Just connect RxD / TxD and GND as shown in this picture (LPCXpresso1317 board  :D ):
[img=480x305]http://www.lpcware.com/system/files/FTDI_LPC1317.JPG[/img]
