Self-powered USB
Self-powered USB
lpcware
Content originally posted in LPCWare by cyberstudio on Fri Feb 28 17:28:54 MST 2014
I am using the ROM drivers on LPC11U35. The chip is powered by a power supply, not the USB bus. I did hook up the VBUS detect (PIO0_3) and USB_CONNECT (PIO0_6) pins properly. Will the ROM driver handle USB cable plugs/unplugs automagically? Thanks.
