Content originally posted in LPCWare by mfarnet on Tue May 27 09:27:35 MST 2014 Does anybody know if there is a more expanded version of the "HIDClient.exe" tool? This tool reads and writes only one byte.
Content originally posted in LPCWare by Tsuneo on Tue May 27 11:09:24 MST 2014 1) SimpleHIDWrite by Robert Marquardt http://janaxelson.com/files/SimpleHIDWrite3.zip - Report size is limited to less than 64 bytes - Support report IDs - Support composite/multi-TLCs HID + HID device
2) generic_hid_cs_62 by Jan Axelsons http://janaxelson.com/files/generic_hid_cs_v62.zip - No report size limit, even more than 64 bytes - To support report IDs, source code modification is required - To access the second HID interface on composite/multi-TLCs HID device, you have to touch to the source code.
There are many other "HID client tools" on the web. But they have similar limitations, - report size is limited to 64 bytes - report ID is not supported - doesn’t access to composite/multi-TLCs HID device
