Content originally posted in LPCWare by kempsun on Sun Jul 22 00:54:29 MST 2012
Hi all,
I composted a HID keyboard and CDC in the descriptor,and enumeration seems work find on WIN7 64bit.
But I can only receive from the PC, send to HOST is not working, both HID and CDC bulk in.
EP macros:
#define KEYBOARD_EPNUM 1
/** Endpoint number of the CDC device-to-host notification IN endpoint. */
#define CDC_NOTIFICATION_EPNUM 2
/** Endpoint number of the CDC device-to-host data IN endpoint. */
#define CDC_TX_EPNUM 3
/** Endpoint number of the CDC host-to-device data OUT endpoint. */
#define CDC_RX_EPNUM 4
Descriptor:
const USB_Descriptor_Configuration_t PROGMEM ConfigurationDescriptor =
.Config =
.Header = {.Size = sizeof(USB_Descriptor_Configuration_Header_t), .Type = DTYPE_Configuration},
.TotalConfigurationSize = sizeof(USB_Descriptor_Configuration_t),
.TotalInterfaces = 3,
.ConfigurationNumber = 1,
.ConfigurationStrIndex = NO_DESCRIPTOR,
.ConfigAttributes = (USB_CONFIG_ATTR_BUSPOWERED | USB_CONFIG_ATTR_SELFPOWERED),
.MaxPowerConsumption = USB_CONFIG_POWER_MA(100)
.HID_Interface =
.Header = {.Size = sizeof(USB_Descriptor_Interface_t), .Type = DTYPE_Interface},
.InterfaceNumber = 0x00,
.AlternateSetting = 0x00,
.TotalEndpoints = 1,
.Class = HID_CSCP_HIDClass,
.SubClass = HID_CSCP_BootSubclass,
.Protocol = HID_CSCP_KeyboardBootProtocol,
.InterfaceStrIndex = NO_DESCRIPTOR
.HID_KeyboardHID =
.Header = {.Size = sizeof(USB_HID_Descriptor_HID_t), .Type = HID_DTYPE_HID},
.HIDSpec = VERSION_BCD(01.11),
.CountryCode = 0x00,
.TotalReportDescriptors = 1,
.HIDReportType = HID_DTYPE_Report,
.HIDReportLength = sizeof(KeyboardReport)
.HID_ReportINEndpoint =
.Header = {.Size = sizeof(USB_Descriptor_Endpoint_t), .Type = DTYPE_Endpoint},
.EndpointAddress = (ENDPOINT_DIR_IN | KEYBOARD_EPNUM),
.Attributes = (EP_TYPE_INTERRUPT | ENDPOINT_ATTR_NO_SYNC | ENDPOINT_USAGE_DATA),
.EndpointSize = KEYBOARD_EPSIZE,
.PollingIntervalMS = 0x10
.IAD =
.Header = {.Size = sizeof(USB_Descriptor_Interface_Association_t), .Type = DTYPE_InterfaceAssociation},
.FirstInterfaceIndex = 1,
.TotalInterfaces = 2,
.Class = 0x02,
.SubClass = 0x02,
.Protocol = 0x00,
.IADStrIndex = NO_DESCRIPTOR
.CDC_CCI_Interface =
.InterfaceNumber = 1,
.AlternateSetting = 0,
.Class = CDC_CSCP_CDCClass,
.SubClass = CDC_CSCP_ACMSubclass,
.Protocol = CDC_CSCP_ATCommandProtocol,
.CDC_Functional_Header =
.Header = {.Size = sizeof(USB_CDC_Descriptor_FunctionalHeader_t), .Type = DTYPE_CSInterface},
.Subtype = CDC_DSUBTYPE_CSInterface_Header,
.CDCSpecification = VERSION_BCD(01.10),
.CDC_Functional_ACM =
.Header = {.Size = sizeof(USB_CDC_Descriptor_FunctionalACM_t), .Type = DTYPE_CSInterface},
.Subtype = CDC_DSUBTYPE_CSInterface_ACM,
.Capabilities = 0x06,
.CDC_Functional_Union =
.Header = {.Size = sizeof(USB_CDC_Descriptor_FunctionalUnion_t), .Type = DTYPE_CSInterface},
.Subtype = CDC_DSUBTYPE_CSInterface_Union,
.MasterInterfaceNumber = 1,
.SlaveInterfaceNumber = 2,
.CDC_NotificationEndpoint =
//.EndpointAddress = (ENDPOINT_DESCRIPTOR_DIR_IN | CDC_NOTIFICATION_EPNUM),
.EndpointAddress = (ENDPOINT_DIR_IN | CDC_NOTIFICATION_EPNUM),
.EndpointSize = CDC_NOTIFICATION_EPSIZE,
.PollingIntervalMS = 0xFF
.CDC_DCI_Interface =
.InterfaceNumber = 2,
.TotalEndpoints = 2,
.Class = CDC_CSCP_CDCDataClass,
.SubClass = CDC_CSCP_NoDataSubclass,
.Protocol = CDC_CSCP_NoDataProtocol,
.CDC_DataOutEndpoint =
//.EndpointAddress = (ENDPOINT_DESCRIPTOR_DIR_OUT | CDC_RX_EPNUM),
.EndpointAddress = (ENDPOINT_DIR_OUT | CDC_RX_EPNUM),
.Attributes = (EP_TYPE_BULK | ENDPOINT_ATTR_NO_SYNC | ENDPOINT_USAGE_DATA),
.EndpointSize = CDC_TXRX_EPSIZE,
.PollingIntervalMS = 0x01
.CDC_DataInEndpoint =
//.EndpointAddress = (ENDPOINT_DESCRIPTOR_DIR_IN | CDC_TX_EPNUM),
.EndpointAddress = (ENDPOINT_DIR_IN | CDC_TX_EPNUM),
Anyone has any idea?
I'm blandly new of embed development. Thanks for help.
