lpcware
LPC4337 Two usb host
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by snovik on Thu Apr 03 00:06:29 MST 2014
Hi.
1) I tried this project (NXP Dual USB Solution), It works fine. I need to implement the same, only use the second usb flash instead of sd card (Copying the contents usb1 flash on usb2 flash).
Is it possible to use two ports usb lpc4337 as hosts together?
Thanks.
