lpcware
Help for Mass Storage Host
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by Marco72 on Mon Nov 14 22:53:13 MST 2011
Hi , I am studying the mass storage host example.
My enviroment is LPCXpresso v4.0.5 [Build 123] + LPCXpressso LPC1769 REV B, plugged on a breadboard where is the USB connector ( and some resistor as for some examples found on LPCXpresso support forum).
The lib is "nxpUSBlib v0.90 beta"
I have 3 USB memory key, 2 of them work without errors but one not work.
The not working naturally works plugged to PC.
Debugging I found that the program remain always locked in WaitForTransferComplete function when this function is called within MS_Host_RequestSense because of calling EVENT_USB_Host_DeviceEnumerationComplete.
So the enumeration happen but there is a problem in "sense requesting".
Thank you very much for any help to understand what happen.
Ciao
Marco
