AM0 & AM1 bits in DYNAMICCONFIG0 register in EMC block
lpcware
Content originally posted in LPCWare by hamedb3269 on Sat Feb 28 09:50:48 MST 2015
How to calculate the AM0 & AM1 bits in DYNAMICCONFIG0 register in EMC block?
I am using LPC1788 microcontroller.
I am using K4S561632C SDRAM.(4M * 16bit * 4banks)
lpcware
Content originally posted in LPCWare by mc on Sat Mar 07 11:19:56 MST 2015
You can use one one them. I would like to use second one first (Bank row and column). Your mode command will be different as well.
Please read below app note for better understanding.
http://www.nxp.com/documents/application_note/AN10935.pdf
lpcware
Content originally posted in LPCWare by hamedb3269 on Sat Mar 07 08:55:32 MST 2015
No one to answer?
