emWIN5 touch problem 触屏问题
lpcware
Content originally posted in LPCWare by xiaobobo2008 on Sun Mar 17 21:02:17 MST 2013
在触摸屏驱动中的程序
static void readAndFilter(int32_t *x, int32_t* y, int32_t* z)
  int32_t ix, iy, iz1, iz2 = 0;
  int32_t lastx, lasty, lastz1, lastz2 = 0;
  int i = 0;
  *x = 0;
  *y = 0;
  *z = 0;
  lasty = getFilteredValue(READ_X(0)); //READ_Y(0)交换 X Y
  lasty >>= 3;
  if (lasty >= 4095) {
    lasty = 0;
  _DBG("\r\n lasty data is:");_DBD32(lasty);
  lastx = getFilteredValue(READ_Y(0)); //READ_X(0)
  lastx >>= 3;
  if (lastx >= 4095) {
    lastx = 0;
  _DBG("\r\n lastx data is:");_DBD32(lastx);
  lastz1 = getFilteredValue(READ_Z1(0));
  lastz1 >>= 3;
  _DBG("\r\n lastz1 data is:");_DBD32(lastz1);
  lastz2 = getFilteredValue(READ_Z2(0));
  lastz2 >>= 3;
  _DBG("\r\n lastz2 data is:");_DBD32(lastz2);
  if (lastx && lastz1)
   *z = (lastx * ABS(lastz2 - lastz1)) / lastz1;
  else
   *z = 0;
  if (*z > 10500) {
    *z = 0;
  if (*z == 0) {
    return;
  for (i = 0; i < DEBOUNCE_MAX; i++) {
    iy = getFilteredValue(READ_X(0));   // //READ_Y(0)交换 X Y
    iy >>= 3;
    if (ABS (lasty - iy) <= DEBOUNCE_TOL) {
      break;
    lasty = iy;
    ix = getFilteredValue(READ_Y(0));   //READ_X(0)交换 X Y
    ix >>= 3;
    if (ix > 4095) {
      ix = 0;
    if (ABS (lastx - ix) <= DEBOUNCE_TOL) {
      break;
    lastx = ix;
    iz1 = getFilteredValue(READ_Z1(0));
    iz1 >>= 3;
    if (ABS (lastz1 - iz1) <= DEBOUNCE_TOL) {
      break;
    lastz1 = iz1;
    iz2 = getFilteredValue(READ_Z2(0));
    iz2 >>= 3;
    if (ABS (lastz2 - iz2) <= DEBOUNCE_TOL) {
      break;
    lastz2 = iz2;
  *x = ix;
  *y = iy;
  if (ix && iz1) {
   *z = (ix * ABS(iz2 - iz1)) / iz1;
  else {
   *z = 0;
  if (*z > 10500) {
    *z = 0;
其中以下代码是什么原理啊,
  else
   *z = 0;
  if (*z > 10500) {
    *z = 0;
