lpcopen periphiral code for lpc17xx.. does not compile under Linux.
lpcware
Content originally posted in LPCWare by s.achterop@rug.nl on Tue Jun 11 12:21:34 MST 2013
  Dear list,
 lpcxpresso v5.2.4 does not compile (probably) all periph-projects from  lpcopen v1.03.
The nxp_xpresso_1769_board_lib library compiles fine.
The reason is that the include and library pathnames in these projects contain "\" as the path separator,  not "/".
After changing all separators it works fine.
I don't know whether this is the proper solution with respect to windows.
        Sietse
