lpcware
LPC 4088 IAP Hardfaults
Latest reply on Jun 15, 2016 by lpcware
Content originally posted in LPCWare by Blackclaws on Tue Aug 04 09:00:22 MST 2015
I've been trying to use IAP commands on the LPC 4088 platform using the chip library. This so far results in a hard fault every single time.
Using the Chp_IAP_Compare command resulted in a hard fault with the program counter pointing to the start of the area to be compared.
Using the Chip_IAP_PreSectorForReadWrite command results in a jump to the vectors pointing to the usage fault handler.
Any help would be appreciated.
