Hello Mario Ignacio Castaneda Lopez,
Thank You for your reply.
i have send you screenshot of example code, error, and console window.
what i have done.
1)import code as per pdf explanation on JN-UG-3098 on page number 26.
2) as i open code it's show so many error. (please check image)
3)As is showing error still i compile code and you can check console box.
4)i have try few more example like JN-AN-1162/1123/1172/1171 but result is same.
5) i reinstall beyond studio(4165) and tool chain(4141)
JenNet-IP|NXP from this website..
6) In problem window its shows so many error.
some header files are missing its not present in included file or C drive.
Please help.
Hi Dheeraj,
What is the app note that you are trying to compile? The screen that you attached.
Can you compile this application note JN-AN-1162?
Note: The errors you are seeing is Eclipse not being able to resolve various variable and functions within the SDK. But you can compile without problems.
Mario
Hello friends,
this is my first reply to nxp community, i want to flash programmer link to download.
if anyone know how to download flash programmer for jn5168.
Then please let me know.
waiting for your reply.
Hi Dheeraj,
Please download the JN-SW-4107 and follow the link below for the user guide
Support Resources for JN516x MCUs|NXP
http://www.nxp.com/docs/en/user-guide/JN-UG-3007.pdf?fsrch=1&sr=8&pageNum=1
Hope it helps.
Mario
Hello Sir,
Thank you for your reply.
i have install beyond studio JN-SW-4141 and JN-SW-4165.
now i am trying to compile example like JN-AN-1162.
but its not compiling, giving so many error.
please help me out.
if you have any example that i can directly import and successfully compile then please let me know.
i am waiting for your reply.
Hi Dheeraj,
I'm sorry for this.
But, could you please check the console, and you will see all the process without the errors.
Please let me know if you still have this problems.
Mario
