Product Model Design Kit palette exists within the schematic window, and I can pick and place model parts to the schematic, the FSL_TECH_INCLUDE element exists in the top-level circuit.
however, when I simulate, I receive the following error messages within the simulator window:
'FSL_TECH_FET_MET.F1' is an instance of an undefined model 'FSLRFPK_METMOS_v1'
detected by hpeesofsom during netlist flattening.
Undefined variable 'Linewidth' (used by expression 'Pad_Width' defined in the subcircuit 'FSL_FET_Gate_Pad_ECP')
