How to add new flash type to FlashProgrammer?
MK_Sirona
Hi there
I'm using a Logic M5329 EVB with a 16MB ST Micro NAND128W3A2BN6 flash
and I'm trying to write my own config file for it.
So far, I've read the CWFLASHPROWP.pdf and the datasheet. I got all the necessary data for
a new device entry, except for the programming algorithm. I really have no idea which one might
work with the ST Micro NAND.
I'd be glad for any help on the matter.
If anyone got a suitable config file, that'd be too good to be true...
-- Matt
MK_Sirona
Okay, I think I found that one. I'm starting to compare sample datasheets to find a matching command set.
