#include <hidef.h> /* for EnableInterrupts macro */#include "derivative.h" /* include peripheral declarations */#define MASK_BITS1 0xF00 //Masks bits 11-8 on#define MASK_BITS2 0x0F0 //Masks bits 7-4 on#define MASK_BITS3 0x00F //Masks bits 3-0 on #define MASK_NIBBLE 0x0F // Masks buts 7-4 off #define DIGIT_PORT PTFD //Port F used for digits//#define DIGIT_MASK 0xF0 //Used to mask bits 7,6 and 5 in Port F//#define SEG_PORT PTBD // Port B used for segments //#define SEG_MASK 0x7F //Used to mask Port B for correct output//#define Mask_Digits 0x03 //used to mask variable digits to 00000011// Function Prototypes //unsigned char NibbleToSegments(unsigned char);void delay(long int);void Output_Seven_Segments(unsigned char, unsigned char);void main(void);unsigned char NibbleToSegments (unsigned char nibble){ const byte Segment_Lookup[16] = // Lookup table for hex numbers to segments on{ 63,6,91,79,102,109,125,7,127,103,119,124,57,94,121,113}; nibble&=MASK_NIBBLE; return Segment_Lookup[nibble];} void delay(long int n){ long int i; unsigned int j; for (i=0; i<n; i++) for (j=0; j<1000; j++) {}} void Output_Seven_Segments (unsigned char segments ,unsigned char digit){ //Remember: segments variable is formed as: // DP g f e d c b a digit &= Mask_Digits; //Mask variable digit to '00000011' DIGIT_PORT &= ~DIGIT_MASK; // Set all digits OFF // SEG_PORT = segments & SEG_MASK; //Port B assigned vairable segments DIGIT_PORT = (0x80 >> digit); // Turn on the proper digit}void main (void){ unsigned char segment; unsigned int time; EnableInterrupts; /* enable interrupts */ // Set DDRs for output ports SOPT_COPE = 0;//Disable watchdog timer PTADD = 0x02; // Replace XX with the hex value to set the PA2 and PA1 as outputs PTFDD = 0xE0; // Same here, setting the inputs/outputs for port F PTBDD = 0xFF; // Setting the input/outputs for Port B time=0; for (;;) //Loop forever (as always!) { time++; segment=(time&MASK_BITS1); NibbleToSegments(segment); Output_Seven_Segments(segment,0); //Convert to Segments and Output bits (11:8) of time delay(1); segment=(time&MASK_BITS2); NibbleToSegments(segment); Output_Seven_Segments(segment,1); //Convert to Segments and Output bits (7:4) of time delay(1); segment=(time&MASK_BITS3); NibbleToSegments(segment); Output_Seven_Segments(segment,2); //Convert ... bits (3:0) of time delay(1); }}
segment = NibbleToSegment(segment);
