I am have CodeWarrior MPC55xx version 2.2, build 71004. I am using the ICDPPCNEXUS Debugger for CodeWarrior 128K Starter Edition Version 1.13 I am not able to get the board up and running. I hit the connect (reset) button (PEMICRO Connection Manager) to connect the P&E Nexus Multilink to the MPC5567 eval board. I am getting a ton of the same error:
Error: Error in ONCE status register during instruction execution.
This is occurring after/during the initializing ram section of the reset/startup stage of the debugger.Any thoughts on what is causing this issue?
Thank you,
Sean
I have the same problem but with different chip and board...I'm using mpc5643l....
I didn't understand what's the problem...
Can I attach my CW .prj?
Please help me
Fabio
