Hello
Which version of CodeWarrior are you using?
To retrieve that info:
- Start CodeWarrior
- Select Help -> About Freescale CodeWarrior
- Click on "Install Products"
- CodeWarrior version used is displayed on top in the Installed Products dialog.
Which OS is running the new computer you are trying to use (Windows XP, Windows 2000, ..)?
If you wish to connect to a parallel P&E cable, you need to set your remote connection to "PEMICRO_PARALLEL" in the project remote Connection panel.
CrasyCat
