First of all what is it you wish to do with Blue Tooth?
As far as I know, you will have to interface a BT module to the jm chip.
For example, there are blue tooth modules that are serial ports, and use the com port emulation on the pc side. However, there are blue tooth stacks for all sorts of devices.
No, I doubt you will find sample code that does exactly what you want.
