Sampath Seshadri
Loading .elf generated with diab and then using codewarrior
Discussion created by Sampath Seshadri on Apr 10, 2008
Latest reply on Apr 14, 2008 by CrasyCat
I compile outside the IDE using diab compiler. I open the .elf and try to debug it. I debug->connect successfully. I do not see any button for loading software. I also tried to flash the image on to the MPC8360E-RDK. That failed for some reason. Is there any offset I need to mention?
Sampath
