Hi All,
I have been using yocto based image on an IMX6 board. I want to run a script when the system wake up from sleep mode? Do you have any suggestion?
Solved! Go to Solution.
Hi eren
after resuming, next command after "echo mem > /sys/power/state "
is executed, so one can add necessary command after it as in attached
script example.
Hi eren
script example.
