Did you managed to solve the problem?
If not, you could post the transfer descriptors and command queues.
my guess:
- check that the qadc is sending the result to the same rfifo where your edma is picking it up
- check that you have actually set the CFFEn and CFFSn to generate edma request
- check that the edma is correctly pointing to the pop register
