Code: // This is code generated by Processor Expert automatically. // Un-used interrupt ISR(Cpu_Interrupt) { asm(BGND); }
/* ISR prototype */typedef void (*near tIsrFunc)(void);const tIsrFunc _InterruptVectorTable[] @0xFF80 = { /* Interrupt vector table */ /* ISR name No. Address Pri Name Description */ Cpu_Interrupt, /* 0x3F 0xFF80 1 ivVReserved63 unused by PE */ Cpu_Interrupt, /* 0x3E 0xFF82 1 ivVReserved62 unused by PE */ Cpu_Interrupt, /* 0x3D 0xFF84 1 ivVReserved61 unused by PE */ Cpu_Interrupt, /* 0x3C 0xFF86 1 ivVReserved60 unused by PE */ Cpu_Interrupt, /* 0x3B 0xFF88 1 ivVReserved59 unused by PE */ Cpu_Interrupt, /* 0x3A 0xFF8A 1 ivVReserved58 unused by PE */ Cpu_Interrupt, /* 0x39 0xFF8C 1 ivVpwmesdn unused by PE */ Cpu_Interrupt, /* 0x38 0xFF8E 1 ivVportp unused by PE */ Cpu_Interrupt, /* 0x37 0xFF90 1 ivVcan4tx unused by PE */ Cpu_Interrupt, /* 0x36 0xFF92 1 ivVcan4rx unused by PE */ Cpu_Interrupt, /* 0x35 0xFF94 1 ivVcan4err unused by PE */ Cpu_Interrupt, /* 0x34 0xFF96 1 ivVcan4wkup unused by PE */ Cpu_Interrupt, /* 0x33 0xFF98 1 ivVReserved51 unused by PE */ Cpu_Interrupt, /* 0x32 0xFF9A 1 ivVReserved50 unused by PE */ Cpu_Interrupt, /* 0x31 0xFF9C 1 ivVReserved49 unused by PE */ Cpu_Interrupt, /* 0x30 0xFF9E 1 ivVReserved48 unused by PE */ Cpu_Interrupt, /* 0x2F 0xFFA0 1 ivVReserved47 unused by PE */ Cpu_Interrupt, /* 0x2E 0xFFA2 1 ivVReserved46 unused by PE */ Cpu_Interrupt, /* 0x2D 0xFFA4 1 ivVReserved45 unused by PE */ Cpu_Interrupt, /* 0x2C 0xFFA6 1 ivVReserved44 unused by PE */ Cpu_Interrupt, /* 0x2B 0xFFA8 1 ivVReserved43 unused by PE */ Cpu_Interrupt, /* 0x2A 0xFFAA 1 ivVReserved42 unused by PE */ Cpu_Interrupt, /* 0x29 0xFFAC 1 ivVReserved41 unused by PE */ Cpu_Interrupt, /* 0x28 0xFFAE 1 ivVReserved40 unused by PE */ Cpu_Interrupt, /* 0x27 0xFFB0 1 ivVcan0tx unused by PE */ Cpu_Interrupt, /* 0x26 0xFFB2 1 ivVcan0rx unused by PE */ Cpu_Interrupt, /* 0x25 0xFFB4 1 ivVcan0err unused by PE */ Cpu_Interrupt, /* 0x24 0xFFB6 1 ivVcan0wkup unused by PE */ Cpu_Interrupt, /* 0x23 0xFFB8 1 ivVflash unused by PE */ Cpu_Interrupt, /* 0x22 0xFFBA 1 ivVeeprom unused by PE */ Cpu_Interrupt, /* 0x21 0xFFBC 1 ivVReserved33 unused by PE */ Cpu_Interrupt, /* 0x20 0xFFBE 1 ivVspi1 unused by PE */ Cpu_Interrupt, /* 0x1F 0xFFC0 1 ivViic unused by PE */ Cpu_Interrupt, /* 0x1E 0xFFC2 1 ivVReserved30 unused by PE */ Cpu_Interrupt, /* 0x1D 0xFFC4 1 ivVcrgscm unused by PE */ Cpu_Interrupt, /* 0x1C 0xFFC6 1 ivVcrgplllck unused by PE */ Cpu_Interrupt, /* 0x1B 0xFFC8 1 ivVtimpabovf unused by PE */ Cpu_Interrupt, /* 0x1A 0xFFCA 1 ivVtimmdcu unused by PE */ Cpu_Interrupt, /* 0x19 0xFFCC 1 ivVporth unused by PE */ Cpu_Interrupt, /* 0x18 0xFFCE 1 ivVportj unused by PE */ Cpu_Interrupt, /* 0x17 0xFFD0 1 ivVatd1 unused by PE */ Cpu_Interrupt, /* 0x16 0xFFD2 1 ivVatd0 unused by PE */ Cpu_Interrupt, /* 0x15 0xFFD4 1 ivVsci1 unused by PE */ Cpu_Interrupt, /* 0x14 0xFFD6 1 ivVsci0 unused by PE */ Cpu_Interrupt, /* 0x13 0xFFD8 1 ivVspi0 unused by PE */ Cpu_Interrupt, /* 0x12 0xFFDA 1 ivVtimpaie unused by PE */ Cpu_Interrupt, /* 0x11 0xFFDC 1 ivVtimpaaovf unused by PE */ Cpu_Interrupt, /* 0x10 0xFFDE 1 ivVtimovf unused by PE */ Cpu_Interrupt, /* 0x0F 0xFFE0 1 ivVtimch7 unused by PE */ Cpu_Interrupt, /* 0x0E 0xFFE2 1 ivVtimch6 unused by PE */ Cpu_Interrupt, /* 0x0D 0xFFE4 1 ivVtimch5 unused by PE */ Cpu_Interrupt, /* 0x0C 0xFFE6 1 ivVtimch4 unused by PE */ Cpu_Interrupt, /* 0x0B 0xFFE8 1 ivVtimch3 unused by PE */ Cpu_Interrupt, /* 0x0A 0xFFEA 1 ivVtimch2 unused by PE */ Cpu_Interrupt, /* 0x09 0xFFEC 1 ivVtimch1 unused by PE */ Cpu_Interrupt, /* 0x08 0xFFEE 1 ivVtimch0 unused by PE */ Cpu_Interrupt, /* 0x07 0xFFF0 1 ivVrti unused by PE */ Cpu_Interrupt, /* 0x06 0xFFF2 1 ivVirq unused by PE */ Cpu_Interrupt, /* 0x05 0xFFF4 - ivVxirq unused by PE */ Cpu_Interrupt, /* 0x04 0xFFF6 - ivVswi unused by PE */ Cpu_Interrupt, /* 0x03 0xFFF8 - ivVtrap unused by PE */ /* Reset handler name */ _EntryPoint, /* 0x02 0xFFFA - ivVcop unused by PE */ _EntryPoint, /* 0x01 0xFFFC - ivVclkmon unused by PE */ _EntryPoint /* 0x00 0xFFFE - ivVreset used by PE */};
