Codewarrior: How to use CW to generate device driver? Which component?
carlpeng
How to use CW to generate device driver?  which CW component should I purchase?
Could you please share a user manual and software component link to me?
I am debugging p4080.
Thanks!
Pavel
CodeWarrior can be used for debugging the Linux kernel or Linux Application. See the Chapter 7 of the Targeting_PA_Processors.pdf file.
http://free-electrons.com/doc/training/linux-kernel/linux-kernel-slides.pdf
See also the following: https://www.quora.com/Whats-the-best-way-to-learn-device-driver-development-on-Linux
Pavel Chubakov
