如何配置这个文件:P10xx-P20xxRDB_P2010_init_sram.tcl
xuchen
以下为该文件官方给出的配置内容:
# Initialization file for P10xx-P20xxRDB board with P2010 CPU
# Clock Configuration:
#       CPU:1200 MHz, CCB: 600 MHz,
#       DDR: 666 MHz, SYSCLK:  50 MHz
variable CCSRBAR 0xFF700000
proc CCSR {reg_off} {
  global CCSRBAR
  return p:0x[format %x [expr {$CCSRBAR + $reg_off}]]
proc apply_e500v2_workaround {} {
  # After reset, e500 cores need to run before being able to enter debug mode.
  # Work-around: set a HW BP at reset address and run the core; after the core hits the BP, it enters debug mode
  # e500 cores need to have valid opcode at the interrupt vector
  variable SPR_GROUP "e500 Special Purpose Registers/"
  # Set a breakpoint at the reset address
  reg ${SPR_GROUP}IAC1 = 0xfffffffc
  reg ${SPR_GROUP}DBCR0 = 0x40800000
  reg ${SPR_GROUP}DBCR1 = 0x00000000
  # Run the core
  config runcontrolsync off
  go
  wait 50
  config runcontrolsync on
  stop
  # Clear affected registers
  reg ${SPR_GROUP}DBSR  = 0x01CF0000
  reg ${SPR_GROUP}DBCR0 = 0x41000000
  reg ${SPR_GROUP}IAC1  = 0x00000000
  reg ${SPR_GROUP}CSRR0 = 0x00000000
  reg ${SPR_GROUP}CSRR1 = 0x00000000
proc init_board {} {
  global CCSRBAR
  # disable Boot Page Translation Register
  mem [CCSR 0x20] = 0x00000000
  # Invalidate again BR0 to prevent flash data damage in case
  # the boot sequencer re-enables CS0 access
  mem [CCSR 0x5000] = 0x00001000
  # configure internal SRAM at 0x00000000
  # L2CTL
  # bit 0 = 0 - L2E: L2 SRAM disabled
  # bit 1 = 1 - L2I: L2 flash invalidate
  # bit 2-3 = 10 - L2SIZ: = 512K
  # bit 13-15 = 010 - L2SRAM: One half is SRAM (256K)
  mem [CCSR 0x20000] = 0x60020000
  # L2SRBAR0
  # bit 0-17 = BASE addr: 0x00000000
  mem [CCSR 0x20100] = 0x00000000
  # L2SRBAREA0
  # bit 28-31 = EXTENTED BASE addr: 0x00000000
  mem [CCSR 0x20104] = 0x00000000
  # L2CTL
  # bit 0 = 1 - L2E: L2 SRAM enable
  mem [CCSR 0x20000] = 0xA0020000
  # Memory Windows
  # 0xFF000000 0xFFFFFFFF LAW0 Local Bus NOR FLASH - 16M
  #   0xF8000000  0xF80FFFFF  LAW5    Local Bus NAND FLASH 1M
  # configure local access windows
  # LAWBAR0 - Local Bus
  # bit 8 - 31 = 0xFF000000 - base addr
  mem [CCSR 0xc08] = 0x000ff000
  # LAWAR0
  # bit 0 = 1 - enable window
  # bit 7-11 = 00100 - Local Bus
  # bit 26 - 31 =  011011 16M - size
  mem [CCSR 0xc10] = 0x80400017
  # LAWBAR5 - Local Bus
  # bit 8 - 31 = 0xF8000000 - base addr
  mem [CCSR 0xca8] = 0x000f8000
  # LAWAR5
  # bit 26-31 = 010011 1M - size
  mem [CCSR 0xcb0] = 0x80400013
  # configure Local Bus memory controller
  # CS0 - Flash
  # BR0 base address at 0xF8000000, port size 16 bit, GPCM, valid
  mem [CCSR 0x5000] = 0xFF001001
  # OR0 16MB flash size
  mem [CCSR 0x5004] = 0xFF000FF7
  # CS1 - NAND Flash
  # BR1 base address at 0xF8000000, port size  8 bit, FCM, valid
  mem [CCSR 0x5008] = 0xF8000C21
  # OR1 1MB size
  mem [CCSR 0x500C] = 0xFFF80396
  # LBCR
  mem [CCSR 0x50d0] = 0x40000000
  # LCRR
  mem [CCSR 0x50d4] = 0x80000008
proc P10xx_P20xx_P2010_init_core {} {
  global CCSRBAR
  variable SSP_GROUP "Standard Special Purpose Registers/"
  variable CAM_GROUP "regPPCTLB1/"
  variable GPR_GROUP "General Purpose Registers/"
  # move CCSR at 0xE0000000
  # CCSRBAR
  # bit 8 - 23 - BASE_ADDR
  mem [CCSR 0x0] = 0x000e0000
  set CCSRBAR 0xe0000000
  # invalidate BR0
  # ABIST off
  # L2ERRDIS[MBECCDIS]=1 L2ERRDIS[SBECCDIS]=1
  mem [CCSR 0x20E44] = 0x0000000C
  # activate debug interrupt and enable SPU
  reg ${SSP_GROUP}MSR = 0x02000200
  # Memory Map
  #   0x00000000  0x0003FFFF SRAM            256K
  # 0xE0000000 0xE00FFFFF CCSRBAR Space    1M
  #   0xF8000000  0xF80FFFFF  LocalBus NAND FLASH 1M
  #   0xFF000000 0xFFFFFFFF  LocalBus NOR FLASH 16M
  # MMU  initialization
  # define 1MB    TLB1 entry 1: 0xE0000000 - 0xE00FFFFF; for CCSR Space, non cacheable
  reg ${CAM_GROUP}L2MMU_CAM1 = 0x500003CAFC080000E0000000E0000001
  # define 16MB  TLB1 entry 2: 0xFF000000 - 0xFFFFFFFF; for Local Bus, non cacheable
  reg ${CAM_GROUP}L2MMU_CAM2 = 0x70000FCAFC080000FF000000FF000001
  # define 256KB  TLB1 entry 3: 0x00000000 - 0x0003FFFF; for internal chip SRAM
  reg ${CAM_GROUP}L2MMU_CAM3 = 0x400001C0FC0800000000000000000001
  # define 1MB    TLB1 entry 7: 0xF8000000 - 0xF80FFFFF; for NAND, cache inhibited
  reg ${CAM_GROUP}L2MMU_CAM7 = 0x500003CAFC080000F8000000F8000001
  init_board
  ### interrupt vectors initialization
  ###interrupt vectors in internal SRAM
  # IVPR (default reset value)
  reg ${SPR_GROUP}IVPR = 0x00000000
  # interrupt vector offset registers
  # IVOR0 - critical input
  reg ${SPR_GROUP}IVOR0 = 0x00000100
  # IVOR1 - machine check
  reg ${SPR_GROUP}IVOR1 = 0x00000200
  # IVOR2 - data storage
  reg ${SPR_GROUP}IVOR2 = 0x00000300
  # IVOR3 - instruction storage
  reg ${SPR_GROUP}IVOR3 = 0x00000400
  # IVOR4 - external input
  reg ${SPR_GROUP}IVOR4 = 0x00000500
  # IVOR5 - alignment
  reg ${SPR_GROUP}IVOR5 = 0x00000600
  # IVOR6 - program
  reg ${SPR_GROUP}IVOR6 = 0x00000700
  # IVOR8 - system call
  reg ${SPR_GROUP}IVOR8 = 0x00000c00
  # IVOR10 - decrementer
  reg ${SPR_GROUP}IVOR10 = 0x00000900
  # IVOR11 - fixed-interval timer interrupt
  reg ${SPR_GROUP}IVOR11 = 0x00000f00
  # IVOR12 - watchdog timer interrupt
  reg ${SPR_GROUP}IVOR12 = 0x00000b00
  # IVOR13 - data TLB errror
  reg ${SPR_GROUP}IVOR13 = 0x00001100
  # IVOR14 - instruction TLB error
  reg ${SPR_GROUP}IVOR14 = 0x00001000
  # IVOR15 - debug
  reg ${SPR_GROUP}IVOR15 = 0x00001500
  # IVOR32 - SPE-APU unavailable
  reg ${SPR_GROUP}IVOR32 = 0x00001600
  # IVOR33 - SPE-floating point data exception
  reg ${SPR_GROUP}IVOR33 = 0x00001700
  # IVOR34 - SPE-floating point round exception
  reg ${SPR_GROUP}IVOR34 = 0x00001800
  # IVOR35 - performance monitor
  reg ${SPR_GROUP}IVOR35 = 0x00001900
  # put a valid opcode at debug and program exception vector address
  mem v:0x00000700 = 0x48000000
  mem v:0x00001500 = 0x48000000
  reg ${SSP_GROUP}MSR = 0x02001200
  # time base enable
  # HID0
  reg ${SPR_GROUP}HID0 = 0x00004000
  # NAND Flash settings - FMR
  mem [CCSR 0x50E0] = 0x0000F020
  # CW debugger settings
  #Trap debug event enable
  #  set the PC at the reset address (for debug-->connect)
  reg ${GPR_GROUP}PC = 0xFFFFFFFC
  # for debugging starting at program entry point when stack is not initialized
  reg ${GPR_GROUP}SP = 0x0000000F
proc envsetup {} {
  # Environment Setup
  radix x
  config hexprefix 0x
  config MemIdentifier v
  config MemWidth 32
  config MemAccess 32
  config MemSwap off
# Main
envsetup
我想知道MMU  initialization部分如何配置?
例如以下配置:
1、为什么要把entry 2 配置成 Local Bus, 该寄存器每一位表示什么含义在什么文档里面能找到,我在P2020RM中没有找到其具体定义?
2、整个tcl文档有相关配置说明文档么?
longqiluo
hello,I have same question about RAM initialized scritp ,  how to modified MMU  initialization part,like this:
ufedor
Sorry, which "same question"?
What has to be modified?
longqiluo
hello,ufedor,my same question is that I also don't know how to modified MMU
initialization part in RAM initialized scritp,attached is my initialization
script ,could you check itfor me especially the part of MMU initialization?My
nor flash is 32Mx16x1,my uboot is 512k,so falsh base address is 0xfc000000,
flash size 64MB,OR0 and BR0 are adjusted,but not TLB.if you know the problem
please guide me or modified it directly,thank you !
ufedor д:
NXP Community
Re: ÈçºÎÅäÖÃÕâ¸öÎļþ£ºP10xx-P20xxRDB_P2010_init_sram.tcl
reply from ufedor in QorIQ Processing Platforms - View the full discussion
Reply to this message by replying to this email, or go to the message on NXP
Community
Start a new discussion in QorIQ Processing Platforms by email or at NXP
Community
Following Re: ÈçºÎÅäÖÃÕâ¸öÎļþ£ºP10xx-P20xxRDB_P2010_init_sram.tcl in these
streams: Inbox
This email was sent by NXP Community because you are a registered user.
You may unsubscribe instantly from NXP Community, or adjust email frequency in
your email preferences
ufedor
Please send your questions as response to the email from the Technical Case.
ufedor
Please pose English questions.
