I am using imx6ul evk with self build yocto with following configuration given for building yocto
DISTRO=fsl-imx-fb MACHINE=imx6ulevk source fsl-setup-release.sh -b image_4_1_15
bitbake fsl-image-machine-test
with Linux kernel version 4.1.15
Thus after building only dtb file has been generated. Where I can find dts file for imx6ul evk board and how can I generate dtb file from dts after modifying it?
Also any dts tutorial? How can make changes in dts file according to sensors added to imx6ul evk?
Solved! Go to Solution.
Basically DTS files are located in arch/arm/boot/dts/.
As for compiling the dts, please refer to the following discussion.
https://community.nxp.com/message/652355#comment-652355
Yuri
Yuri
