Hi,   I'm converting over from using the IAR compiler for...
Question asked by Phillip WOLSTENCROFT on Mar 18, 2008
Latest reply on Mar 20, 2008 by bigmac
I'm converting over from using the IAR compiler for the HCS12.
I have found that CodeWarrior does not support a nifty function generation attribute called "__monitor".
This attribute causes the function to generate code to, on entry, save the current interrupt enable status & disable interrupts; then, on exit, restore the saved interrupt enable status.
This is a really useful tool.
Does anyone know of an implementation work around for CodeWarrior or whether Freescale intends to support this functionality?
regards
PhilW
