Is below i.MX6 Solo CLK1_N / CLK1_P with oscillator connection right or not?
The oscillator connection seems to be correct, just make sure about the clock configurations if the application also requires a crystal between CLK2_N and CLK2_P. For additional details, you could also refer to Table 2-7 “Oscillator and clock recommendations” of the document titled “Hardware Development Guide for i.MX 6Quad, 6Dual, 6DualLite, 6Solo Families of Applications Processors”, available at the following link:
http://www.nxp.com/files/32bit/doc/user_guide/IMX6DQ6SDLHDG.pdf
Hope this will be useful for you.
Best regards!
/Carlos
