p1020-wlan u-boot debugging using codewarrior
nimeshkanoth
Hi All,
we trying sd card boot u-boot.bin debugging in p1020-wlan board using code-warrior, we followed the document AN4876(CodeWarrior U-Boot Debugging),but failed in run configurations step with error Program is not a recognized executable.
we are using code-warrior 10.5.1 version.
please find the attached u-boot executable and snapshot of code-warrior ide.
Original Attachment has been moved to: u-boot.bin.zip
addiyi
Please take a look on Chapter 4. You have to use Import option and import the elf image.
Adrian
nimeshkanoth
Hi Adrian,
yes we have used import option and imported u-boot.bin file generated while building the u-boot for sdcard boot.
Nimesh
addiyi
You have to import elf file not bin.
Adrian
