Hi. I am using MPC5644A
I set up eSCI module 152000 Baudrate
When I receive messege of 9600 Baudrate, I can detect a wrong Baudrate ??
For example, Flag or Interrupt
Solved! Go to Solution.
you should get Framing Error Interrupt Flag after you receive data with incorrect baud rate. Look at the register eSCI_IFSR1 bit FE.
Martin
Martin
