I have reset the NTAG I2C demo board thru my Android app, but now it does not work anymore. Can I fix this?
I just checked again. The only problem is that it won't start the app when holding my phone on the antenna. (It says: "Item not found"). If I start the app before by hand, it will work with the pcb and it will communicate.
Hello Jan ten Wolde:
It is possible that the Android application record in your NTAG I2C tag is not correct or it was corrupted, so the application cannot be found.
Try restoring the NTAG I2C contents with the Write NDEF option of the Android app. Make sure to enable the checkbox for Add NTAG I2C Demo AAR:
I hope this resolves the issue.
Regards!
Jorge Gonzalez
