Dear community.
Our customer has question below.
Customer has able to capture analog video at iMX6 solo,
However,video capture supported by the YUV444 only but I require YUV422 format.
I am Format conversion is necessary but i could not be found .
Would you please provide information for YUV444 → YUV422 conversion library .
Thanks Best.
mx6S has IPU which has CSC module to change color space conversion by hardware, for more detailed inforamtion, pls refer to the chapter 38.4.9.5 Color Space Conversion unit - CSC
<http://cache.nxp.com/files/32bit/doc/ref_manual/IMX6SDLRM.pdf?fpsp=1&WT_TYPE=Reference Manuals&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation&fileExt=.pdf>.
