I want To Integrate pdftcl and tk package into codewarrior it is possible?
ganeshmaseedu
Can you please help me how to add different packages into exisiting TCL Because i am getting a problem while compiling
below tcl code
package require pdf4tcl
package require Itcl
package require Testing
package require Tk
Carlos_Mendoza
Hi Ganesh,
In which path are your package files stored? Please try placing them on C:\Freescale\CW MCU v10.6\MCU\bin.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
aayushi_bhatiya
I tried all the suggested ways but still it is not working for Codewarrior 10.7. I have created a custom package which I want to use in TCL script.
I have created a custom package using pkg_mkIndex . *.tcl command but I am getting error like pkg_mkIndex command doesn't exist.
Please provide some suggestion.
Thanks & Regards,
Aayushi Bhatiya
jorge_a_vazquez
Hi Ganesh Maseedu
Could you please tell us what MCU are you using? and What version of Code Warrior?
Have a great day.
Jorge Alcala
ganeshmaseedu
Hi Jorge,
- I am Using CodeWarrior   Version: 10.6 , Build Id:140329
   MCU  FXTH870000  HCS08 family
S08 Disassembler
S08 Linker
S08 Burner
HCS08 Compiler
HCS08 Assembler
HCS08 Preprocessor
Carlos_Mendoza
Hi Ganesh,
Hope it helps!
Carlos Mendoza
ganeshmaseedu
Hi ,
Currently I added in this C:\Freescale\CW MCU v10.6\MCU\ccs\lib path
But it is not working,
I tried your suggested path on C:\Freescale\CW MCU v10.6\MCU\bin still it is not working.
Tk is Already Available C:\Freescale\CW MCU v10.6\MCU\ccs\lib path in this path but while calling in script
Package require tk command package not available I am getting . please help me where can I add .
Thanks & Reagrds
Ganesh Maseedu,
S/o Nageswararao Maseedu & Santha Kumari Maseedu,
Wabco India Ltd,
Ph:+91-9966143725,
Chennai.
