imx6Q-CAN driver
imx6Q-CAN driver
创世之枪
CPU:IMX6Q
I want to design a bare board can driver, but something goes wrong, and I don't know how to  solve it:
When I loopback CAN1 and CAN2 everything is right!
But when I disconnect them ,there are bus errors all the time !
And I can't send or receive any data from other board.
I'm sure the baud rate is right, and the pins are right.
How to config flexcan's registers?
I copy from Linux.
Thx~~~~~~~~~~~~~~~~~
Labels (3)
Tags (4)
for bare metal flexcan example one can look at attached sdk example,
with description in Chapter 11 Configuring the FlexCAN Modules
in pdf document.
in pdf document.
创世之枪
I can loopback CAN1 and CAN2,but there is always bus error when I connect with can tester....
for can tester please try procedure given in attached files.
~igor
