Hello, I could not find any document explains the difference between MC9S08PT32 and MC9S08PT32A. could you please help for this?
Solved! Go to Solution.
It means product Revision.
A = Rev. 2 or later version, this is recommended for new design.
hi;
more information required
Only info I can find is from this datasheet
http://cache.freescale.com/files/microcontrollers/doc/data_sheet/MC9S08PT60.pdf
