How to use multi-core for the MPC5748G
Question asked by chfakht chfakht on Jun 5, 2016
Latest reply on Mar 1, 2017 by Lukas Zadrapa
Hi everyone,
I'm trying to implement the LZMA algorithm (compression/decompression algorithm) in the MPC5748G, however i need an example on how to use more than one core since there are 2 cores of 160Mhz
I'm using LZMA to reduce flashing time, the file firstly is compressed and then sent to the MPC ... it should then decompress the file and perform the flashing operation.
The algorithm need to run on a separate core because the other core are doing other things and contains a lot of tasks.The results are not very good and the decompression takes too much time.
Any help for using the other core will be very helpfull,thanks.
