MPX5500DP in a circuit with water
vladimirnerud
Hello, I need to use differential pressure sensor MPX5500DP in a circuit filled with water.
The water temperature is from about 10°C to 40°C. Can this sensor safely use?
Thank you
Vladimir
TomasVaverka
Hello Vladimir,
Please have a look at this thread with a long discussion on this topic.
I hope it helps.
Tomas
