how do i connect freedom to arduino
roberthalversen
I have a Freedom FRDM-KE022Z40M which is not supplied with connectors.  I found 0.100" female headers from Digikey that should fit but I do not understand how this will mate with Arduino R3 boards.  Does Freescale (NXP) have recommended connectors that will allow me to connect to the Arduino board?  Do you have any pictures showing the two boards connected?
Robert
ZhangJennie
Hello Robert,
I don't have experience on connecting FRDM with Arduino R3 board. But I know Erich ever wrote a set of articles on this related. Can you please check if this can be helpful to you:
https://mcuoneclipse.com/2012/09/28/kl25z-freedom-board-and-arduino-headers/
https://mcuoneclipse.com/2012/12/14/frdm-kl25z-with-the-arduino-motor-shield/
https://mcuoneclipse.com/2014/01/05/frdm-with-ardino-ethernet-shield-r3-part-1-sd-card/
Jennie Zhang
ZhangJennie
Hello Robert,
Jennie Zhang
