How to Enable the PTUT0PE to show the internal trigger_0 event on Pin PS0?
chenqizhi
Hi,in my application,I use the S12ZVML(F1) to control a PMSM motor . To confirm the sample time, I have set the PTUT0PE to show trigger_0 event by
PTUDEBUG_PTUT1PE = 1;
PTUDEBUG_PTUT0PE = 1; but I can't get any wave in PS0 and PS1(Pin3 and Pin4)?
(I didn't use CAN function)
lama
is the issue still active?
If yes, do you measure the signal in a normal or a special mode because PTUDEBUG is writeable in the special mode only?
Ladislav
chenqizhi
Didn't I descrip clearly?
