FEC driver bug explanation
vladimirovseych
Hello, dear Freescale!
Can you explain a bug with system failure under high network load?
I'm using i.MX287 with two ethernet controllers connected with bridge
On kernel 3.18 (OpenWRT) I catched NETDEV WATCHDOG warning and kernel oops while iperf testing (log.txt).
But when I backported your driver from 4.4.7 to 3.18.29, bug disappeared.
3 files was changed:
  • fec_main.c
  • fec.h
  • fec_ptp.c
What/where is the reason of the failure?
Thanks in advance.
Vladimir.
Original Attachment has been moved to: fec_ptp_old.c.zip
Original Attachment has been moved to: log.txt.zip
Original Attachment has been moved to: fec_old.h.zip
Original Attachment has been moved to: fec.h.zip
Original Attachment has been moved to: fec_main.c.zip
Original Attachment has been moved to: fec_main_old.c.zip
Original Attachment has been moved to: fec_ptp.c.zip
Labels (3)
Hi Vladimir
suggest to post that on linux mail list since nxp does not officially
support i.MX28 for 4.4.7 or 3.18.29 kernels. Supported bsps are located
on official web product page
i.MX28 Evaluation Kit|NXP
