from your screenshot, all the five items are color icons which means they are not fully installed
from the error messages, a certain item should be partly installed and has been recorded by CW.
I suggest you fully uninstall CW and remained install.
reinstall CW10.5, then install "MCU v10.5 Updates for MQX", "CW10.5 update". Please pay attention to the install sequence/
at last install MQX4.1.
see how it works?
Jennie Zhang
thank you ... i followed the same procedure in some other PC and it installed perfectly.....
( Even in my first PC its not , may be CCS i have installed. It might giving issue)
Thank you :smileyhappy::smileyhappy::smileyhappy:
You are welcome! :-)
Can you tell me where exactly i can get MQTT header and neccesary files ? I want to MQTT for MQX.
As I know there is a known discussion regarding to MQTT, see
MQTT client libraryMQTT client library
if above thread can not help you, to separate different subject, can you please create a new thread for MQTT related question? Thanks!
Jennie Zhang
thats really helpfull..
I forgot to menstio that im using GPRS modem(G620) and i need to implemet MQTT client .
see how it works?
Jennie Zhang
MQX 4.1 was developed to work with CW MCU v10.5. It has been tested and confirmed to work with CW MCU v10.6.
please
- uninstall your CW and MQX
- restart computer
- install CW10.5
- install CW10.5 update
- install MQX4.1
- restart computer
see how it works?
Jennie Zhang
i tried but no use..... even i tried with different PC. but no use.
MQX3.8 is working fine. But MQX4.1 giving issue
did you install "MCU v10.5 Updates for MQX" as I highlight below? it's necessary.
Besides I also suggest you install other items I highlighted in purple.
MQX4.1 must be installed AFTER CW10.5 updates installed.
above steps work on many computers for us and customers. please double check.
Jennie Zhang
I installed CW10.5 first
And now i tired to install the updates.
The option which are highlighted in purple, installed without any issue
but the option highlighted in yellow color, giving issue.
