i.mx6 IPU rotate 180 degree
Question asked by ZC Tee on May 30, 2016
Latest reply on May 30, 2016 by ZC Tee
Hi all,
Is the i.mx6 IPU able to do 180 degree rotation in kernel?
In drivers/video/mxc/mxc_ipuv3_fb.c, I saw that there are two lines as below:
     if(var->rotate > IPU_ROTATE_VERT_FLIP)
          var->rotate = IPU_ROTATE_NONE;
Does it means the IPU only can do vertical flip? why is these two lines in the coding?
I am using kernel version 3.0.101.
Tee
