Query on i.MX6Q IBIS model
anandmeharwade
I have downloaded the IBIS model for i.MX6Q and I want to simulate for SATA, PCIe signals. I am Observing that the SATA and PCIe TX diff pairs are assigned as inputs. In this case how can I use the i.Mx6q as driver to transmit the bit pattern
Could you please clarify on this
Anand M
Hi Anand
some pins are not covered by ibis model, as described in Table 9-6. i.MX6 pins not supported by IBIS
i.MX6 System Development User’s Guide
http://cache.freescale.com/files/32bit/doc/user_guide/IMX6DQ6SDLHDG.pdf
Hi Anand
