whether KSDK support K60DN512Z ?
zzyy
hi, everyone. I want to know whether KSDK support K60DN512Z ? I only found K60D512xxx10. What should I do ? thank you.
santiago_gonzal
If you are going to begin a new SW development, K60DN512 is supported in the KSDK and is pin to pin compatible with K60DN512Z, so it's highly recommended that you use the new device, which improves some peripherals and fixes silicon issues.
You have all the changes between both devices here:
http://cache.freescale.com/files/32bit/doc/app_note/AN4445.pdf
Santiago
