Can't Import KDS Project and use 'Copy Projects into Workspace'
Question asked by Ted Mawson on May 26, 2016
Latest reply on Oct 27, 2016 by Deomid Ryabkov
I created a project that was based on the lptmr example for the freedom KL03Z board.  When I did the import originally, I checked the box Copy projects into workspace which made sense as I didn't want to mess up the original files.  However, the project won't compile and gives errors when imported with the Copy projects into workspace box checked.  I ended up importing with this box unchecked but now I've altered my board files, all other KL03 examples I import are broken as the board files are common to all the examples.
Is there a way to work around this?
