Hello Vignesh
128 K flash is enough to run a CAN application. The Data Filed in each frame is up to 64bit. The MSCAN module on KEA128 supports 5 receive buffers and 3 transmit buffers.
How many records would you preserved on flash?
There has an MSCAN driver for KEA128, it can be downloaded from :
http://cache.nxp.com/files/microcontrollers/software/device_drivers/MSCAN_KEA_DEVD.zip
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
