k20 global interrupt
kooroshhajiani
I have a project running in KDS. When I use
__enable_irq();
to enable the global interrupts I keep getting error(undefined reference to it).
Then I used
asm(" CPSIE i");  and it complains about "asm"
My goal is to enable the pin interrupt on port B and I believe I know how to do that however before doing that I need to enable the global interrupts.
the target is a K20 production board.
Any ideas?
Koorosh Hajiani
kooroshhajiani
This issue is fixed. I had to use __asm(double under score).
danielchen
thanks for your sharing.
