I am using the K66 and would like to use the ENET hardware checksum.
I have set:
ENET_TFWR |= ENET_TFWR_STRFWD(1);
ENET_TACC |= ENET_TACC_IPCHK(1) | ENET_TACC_PROCHK(1);
and defined
CHECKSUM_BY_HARDWARE
but the checksum does not work. Is there something else I should do?
Solved! Go to Solution.
You also need to enable the ENET_TACC[SHIFT16] & ENET_RACC[SHIFT16] bits.
Wish it helps.
best regards,
Ma Hui
Wish it helps.
best regards,
Ma Hui
