Question mark (?) on KDS Folders
aerodame
What does the ? mean on a folder in the Project Explorer?  And what does it mean to "FORMAT" the source?
Tags (2)
BlackNight
and another article about how to use workspaces with  version control, see https://mcuoneclipse.com/2013/02/02/eclipse-workspace-tips/
Erich
TICS_Fiona
Hello Stephen
Label Decorations are used by CVS to show important synchronization information about workspace resources.  The ‘?’ decoration on a file or folder icon indicates that the resource is not under version control.
Hope this helps!
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
aerodame
OK, I use GIT and oh, great I see that the ?'s go away when I check in all my files.   One thing that is problematic is all of the .metadata that I can't easily exclude using .gitignore (or don't know what data I should exclude).   Does anyone have advice on best practices there?
Also, to my second question.  What is the Format Source?
TICS_Fiona
Hello Stephen
I have no experience on GIT.   For version control problem, I think user only needs to check in the project folder, excluding ‘Debug’ subfolder.  The “.metadata” records the configurations for workspace, not for project, so “.metadata” can be excluded from version control.
The “Source->Format” commands applies the full  “C/C++ > Code Style > Formatter” preferences to the entire contents of the active editor, or to the selection if there is one.
Best Regards
Fiona Kuang
BlackNight
Hi Stephen,
nothing of the .metadata shall be in the version control system, so you need to exclude it completely.
The common usage with Version control systems is to have the project/project folder *outside* of the workspace, and not inside. that way you do not need to care about the .metadata.
Related to that topic, there is information about what to share and not her:
https://mcuoneclipse.com/2012/03/17/dissection-of-mcu10-projects/
https://mcuoneclipse.com/2013/03/29/version-control-with-processor-expert-projects/
If not using Processor Expert, you can ignore all the things about Processor Expert files.
I hope this helps,
Erich
