PTN3460 Firmware versions
davidmüller
According to the NXP parametric search, there are at least 4 different firmware versions for this chip.
  • Is there a document describing the differences between all these versions?
  • Is there a way to switch between different firmware versions by reprogramming as mentioned in AN11133?
  • If yes, where can I download the firmware files and the necessary programming tool?
